TwinTurbo.NET: Nissan 300ZX forum - Hard to access boost leak! Please Assist
Subject Hard to access boost leak! Please Assist
Posted by Bohemiangod on December 11, 2009 at 9:58 PM
  This message has been viewed 110 times.
Message just replaced the lower and upper manifold with two perfect
units. Did so because my old lower manifold was stripped in all
bolt holes and I assumed it was not sealing the gasket
because of this reason.
I installed the two new pieces with all brand new oem gaskets.
transfered over fuel rails but reused the insulators in between
the rails and lower manifold. I seem to have a boost leak when
pressurizing the intake system that seems likes its coming from
the center of the manifold but I cant seem to find it.
It is a slow leak as the intake system will hold the pressure
and i can boost about 14psi on low boost. haven't been able
to monitor boost close enough to watch it drop off but I am
sure it does as I can hear the pshhhhh sound on testing.
I can see the plenum gasket sticking out around all the edges
of the two mating surfaces so I cant imagine it to be the
cause. What else could be leaking and is there a definitive way
to check what is leaking. I assume spraying water and looking
for bubbles will be the only way, but hard to aim water down
in the manifold mating area precisely.
